Dimensions
Is it possible to set any (self made) block as a dimension arrowhead (like in AutoCad)?
Yes you can. 1. Create the block in the drawing.2. Open the DIMENSIONS SETTINGS window (SETTINGS menu), ARROWS tab page 3. Check the USER-DEFINED ARROWS option.4. In the START and END fields fill in the name of the block.5. Optionally, adjust the ARROW SIZE value.5. Click the SAVE button.
This procedure is outdated since the latest intellicad has a changed interface. blocks now are added to the comboboxes for arrowheads automatically. So you can pick them just like any built in arrowregards, sanderbricscad
