Undo issues
Hi
We have all just upgrade to V21.1.04 from V20 and on all machines now whenever someone does ctrl Z or undo it undoes everything right back to when drawing was opened as opposed to just last item done.
Tried typing Undo then C (control) which brings up set undo control and change this to one.
But open new drawing and it resets back to all??
Everyone else got this issue is is there a setting we need to change in V21 that wasnt there under V20?
Cheers
Brett
I confirm I had this for a while - it just went away!
yikes so weird, everyone here at the office got same issue past 2 weeks now.
So annoying when working away and out habit ctrl Z and everything gone.0 -
There are two different commands _U and _Undo. By default Ctrl+Z should call _U. If this is not the case then you can use the _Customize command to fix this.
That's clarifying. So U is a special case of UNDO?
Also https://help.bricsys.com/hc/en-us/articles/360013572859-UNDO-reverts-too-many-operations
Pity there's not an option to U or UNDO without undoing any Zoom/Pan/Rotates.0 -
@Tom Foster said:
Pity there's not an option to U or UNDO without undoing any Zoom/Pan/Rotates.Yes.
