PointCloud from csv?
How to make a cloud of points from the CSV file?
  • Terry Dotson
    edited June 2021
    If your file is a 3D scan of a building or other 3D structures, skip the following.
    If your file is aerial lidar X,Y,Z and your goal is a TinSurface (and you're running v21 Pro Windows), you can download the free LidarTools for BricsCAD. Change the extension of your file to .XYZ then use it's LIDARCONV command to create a LAZ file, then use it's LIDARTIN command to create the TinSurface.
  • Thanks for sharing that Terry. Interresting!
