crash during "tools-inquiry-distance"
when inquiring as to distance or length of line, the program crashes if the snap mode is set to "intersection" as the only snap. If "end point" and "intersection" are both selected, it does not crash. This has happened repeatedly so appears to be inherent in the software.
  • I use this all of the time and have never had a crash. I checked and verified that I only had the intersection snap set and still no problem. I am running .0025.
  • What build are you using and on what operating system?I'd consider some entity it could have problems with. We found (and fixed) such a problem with some hatches. Can you send a drawing too?regards, sander
  • I am using a 600Mhz PIII with 384MB Ram using Win Nt 4.0 SP6 with the EaglePoint 2000 Civil Software. I am not sure if the problem occurs with or without the EP2000. I will check it out and let you know.
  • well, I just tried it on two separate drawings, with and without EP2000, and it worked just fine. It must be something wierdin one of my drawings (I am not sure which one).
  • I forgot to mention, I am using version 0025.
