Select previous selection
simple question. Is it possible to quickly select the same items as in your last selection?
E.g. I selected 13 specific parts, I made a small mistake and want to do it again. Now I have to make the same selection again (click the 13 parts again), there should be a way to do this faster?
- when you are prompted to selection type p on the command line ...
- SELECT
Select entities to include in set [selection options (?)]: p
Entities in set: 3
- SELECT
Entities in set: 3
dear Ferdinand, I cannot reproduce your answer, could you give me a little bit more explenation?
well, what you have previously selected is still available; the reach what you have previously selected you type p on the command line; so any command that prompts you to select entities (instead of selecting them explicitly), supply "p" (for "previous selection")
hmm, seems not to work. I don't get the last selection. I believe you will get the last selection which you actually edited? Correct me if I am wrong
I also would prefer if important user actions, like Selections,
would just stay until you deselect by clicking in empty Space.Also each separate Selection action should be part of the Undo/Redo
process (while View changes should be NOT),
the same way as it works in any 3D Mesh App, where Selections are
honored as valid user work.0 -
I want selection made 3 ago. A question asked elsewhere needs a bit of typing (setq s1 (ssget)) next time (setq s2 (ssget)) etc move !s1 and so forth.
