Express Tools broken ribbon
Since v21 express tools appears on the ribbon howewer it doesn't look good. (please have a look at attached screenshoot).
I haven't found the way to resize it propely. I tried to unload the express tools riboon (from cui) but it unloads the whole ET module as well.
I would be grateful for any help.
It looks like you have lots of rows in the File Tools and Tools panels. I would recommend moving the tools into 3 rows instead to improve display ability. You can also change the button style for each panel. This may improve the way it looks in BricsCAD.
Thanks for the response. It's a standard express tools cui file which loads automatically (I can't remove it without removing ET totally). So I deleted two panels File Tools and Tools and it's OK
