Problem with displaying linetypes
in 2D Drafting
Hello,
We are using v20 and several linetypes don't have the proper display in modelspace and paperspace on 1 pc.
The dwg file isn't the problem because on the other pc's the linetypes are displayed correctly.
Strange thing is that when i export a PDF, the linetype are displayed correctly in de PDF file.
In modelspace the lines are showed as in attached file 1, and the correct way, in the PDF, as showed in file 2.
Anyone familiar with this problem?
try playing with PSLTSCALE set to 0 and MSLTSCALE set to 1, also PLINEGEN set to 1 also is nice0
