Hyperlinks made in BricsCAD aren't being generated when I plot the drawing.
Hi all,
The problem: I'm trying to make a customer facing product sheet in BricsCAD that has various hyperlinks in it (i.e. the website URL at the bottom of the page ) but I've been struggling to get Foxit Reader & Foxit PDF Editor to recognise my hyperlinks even though I can open these hyperlinks in BricsCAD (left click entity>hold right click>hyperlink).
Context:
-In the plotter settings for my PDF plotter "Export Hyperlink" is checked.
-PDFexporthyperlink value is set to 1 (Not sure if relevant when plotter is being used)
Additional Question:
Does an entity with an attached hyperlink within a block result in a working hyperlink once the PDF has been plotted?
I've had a good look around and I can't quite nail what I'm doing wrong down and would greatly appreciate if anyone could shed some light on the potential issues.
Cheers.
Just used the default plot to pdf and worked fine.
