What command - to stitch 3D faces together? ANSWERED.
edited August 2021 in 3D Modeling
See attached image (as example) - How do I stitch faces together to get 1 mesh entity?
In the attached example all the triangles are independent faces...
  • Hi GrahamG,
    Try DMSTITCH
    Kin
  • AFAIK
    If you have 3D Faces, you have to convert them to Regions first.
    (Select - Create Region)
    Then you can stitch them and will get a Solid
    (if it was a proper Volume)
    or a Surface.
    Which you should be able to convert/degrade to a Mesh, if needed.
  • Thanks Michael,
    Convert to Regions - then DMSTITCH did the ‘trick’…
    Saved as a surface.
    Best….
