File metadata not showing on Windows Explorer
edited September 2021 in Other
Hi all
Is there any obvious way of displaying the file metadata (dwg) on Windows Explorer?
What I noticed so far, is that any file I open with Autocad will display properly!
The same file, saved with Briscad (V21) will render the metada "invisible" to Windows Explorer!
BTW "dwgprops" on both programs show exactly the same metadata.
Cheers !
