Selection modes
I have downloaded version 3.30..3 and having a problem with SelectOnScreen mode in VB. When I execute the code a bonus menu loads up, my code is not executed properly and IntelliCAD freezes up on me. Has this happened to anyone else? I have tried to disable the menu to no avail. Thanks to any help given.
The bonus menu is (re)loaded automatically eacht time IntelliCAD starts up. This is done by the following line in Icad.lsp:(command "_menuload" "bonus.mnu")If this is the only line in your icad.lsp, you can delete the file or remove the line.Then launch IntelliCAD, go to Tools > Customize, select the Toolbars tab and click the RESET button.The bonus tools will not be loaded anymore now.
