Can't change component size
I'm trying to resize the window component but the size changes on a properties(parameters) panel only. In a 3D it is always 1000x1000. DI command tells the same (1000x1000). What am I doing wrong?
  • Version 20.2.09 (x64), Linux
  • You do nothing wrong. This is a quite nasty bug that hits me from time to time (also on ms-windows), but I never managed to track it down enough to make filing a SR worthwhile.
    If you have a 100% reproducible scenario, please report to the devs.
  • Thank you! It works if I create a new drawing.
    Ok, I will
