Chamfer a wall
Kinetic
edited October 2021 in BricsCAD BIM
I bimified a 3d solid to a wall and now I can't chamfer it - do I have to convert it back to a 3d solid, or is there a way to do it?
Thanks for any help.
Apologies, being new I didn't realise I had the wall in an array of 1 column! All good.
  • Various ways to do it depending on what you're after. In example below, first I chamfer the end of one wall by CTRL-selecting the edge and using the _DmChamfer command. Then I make a chamfered corner by adding a polysolid, assigning the same wall composition, and then _LConnect it to the adjacent walls.
