QUAD menu - do not expands
In Briscscad v.18, when I press the right mouse button, the full menu immediately appears (I set it to 15 icon). In Bricscad 21.2.05 (x64) revision c77687b2, only one icon appears when the mouse button is pressed. The icon bar does not expand. The visible mark does not disappear until I move my mouse away or hover over the icon. Only after hovering the cursor over the visible icon, the entire bar unfolds.
All settings are the same as in the old version. I tried to change the 0ms delay to 100ms if the value 0 meant something else but nothing works. Does anyone know something about a possible solution?
Howdy, Stranger!
