Section Views and Section View Labels
I am new to BricsCAD after working with AutoCAD for over 33 years. I am trying to modify the content of the standard section view labels but I cannot find where to do that, other than after they are displayed.
I do not need it to show the scale of the view because I always use section views that are the same scale as the base view, and I would like for it to be center justified.
I also cannot figure out the "full" and "custom" section options. When I select "full" it still shows exactly where the section line is and nothing beyond. If I select "custom", no matter what I enter for the depth the view doesn't change.
I feel certain that I am missing something for both of these issues, but I have no idea what it is or where to look.
Any pointers would be appreciated.
What controls the creation of section view and detail view labels? Section view labels are left justified, detail view labels are center justified, nowhere can I find how to adjust the font size or what is included in the labels. It has to be hidden in there somewhere!
Drawing Explorer
I can't find anything in the View Detail Styles or View Section Styles that actually controls the view labels.
Switching from V21 to V22 "fixed" the problem that I was having with how the section views displayed (see PDF file attached above), but I still cannot find any way to control the label content. I can either turn it on or off, but I can't change how it looks or what it includes. I do NOT want it to show the view scale, and I want to be able to control the font size and justification used in the label.
It was actually a DWG file that I attached, not a PDF file.
Why can't I edit my posts? -
Hi Dustin,
Apologies for the inconvenience.
The bugs regarding attachments and editing comments should be fixed, you can attach your files and edit/delete your comments now.
Kind regards,
Chi-Yan
Howdy, Stranger!
