Polyline editing in-line
I've been trying to find a way to edit polylines in-line. I am so use to converting to arc/ adding vertex in-line.. having to use pedit is very slow. If this is a feature that I have not been able to find please let me know, if not I hope they add this into future updates.
  • By default if you hover over a polyline you will get a dialogue display at the bottom of the screen offering you the choice of hitting "Ctrl" to toggle between polyline select and segment select.
    Hit Ctrl and the quad will allow you to convert to arc, stretch the segment or insert a vertex.
  • The PEDITEXT command is very handy for polyline editing, as is the BREAK command and the Express tool PLJOIN.
