Text Styles and Font substitution
Why does Bricscad substitute any Fonts from DWGs I open by Simplex Font,
although I would have all needed Fonts in my operating system.
Is it ....
a) a Bricscad for macOS Problem
b) a Settings Option
c) or maybe do I need to copy any TTF Font used in a DWG drawing
right inside of the DWG's parent Folder ? (I hope not)
Yes, this seems to have changed from 21 to 22. Not a fan of the new font at all. The Windows version is still as was on 21.
Ah, I see it looks reasonable in V21.
So a Bug ?0 -
Not sure if it's a bug or a change. I had to modify the dimension offset to 1" as the dims were interfering with the arrow lines.
Hmmh, if it worked in V21 and still on Windows ...
For me its smells like a Bug.0 -
I filed an SR ....
            I had the same issue, filed a service request and they responded saying it’s a known issue with V22.
I installed V21 and am having no issues with the fonts using that.0 -
Yes, currently V22 does not recognize the TTF Fonts, only SHX.
(An ancient Egypt standard of font packages ?)
They have it on screen but no time frame .....0 -
New release today and the font issue has been resolved on the Mac OS version.
Great !
Why are you always faster recognizing new Bricscad releases ?
I am sure I checked last evening ....0 -
Haha, just lucky I guess.....
@Michael Mayer said:
Great !Why are you always faster recognizing new Bricscad releases ?
Great fixes in V22.1.05
https://www.bricsys.com/common/releasenotes.jsp?i=71820
