Slow performance when switching between layouts.
BricsCAD hangs or pauses when switching between layouts in a drawing. I'm working in a drawing that have 6 pages. Each page around 7~8 view ports. It takes more or less 15 min to change between pages.
How much ram do you have ?
16gb. When I'm changing between sheets the use of memory can reach 9gb. After it finished to load "cached metafiles" drops to 1,5 gb.
@ALANH said:
How much ram do you have ?16gb. When I'm changing between sheets the use of memory can reach 9gb. After it finished to load "cached metafiles" drops to 1,5 gb.
If you have 6 viewports switched on, each with complex drawings eg. hotel floor plan. That can slow things down.
I forgot to ask: Does it happen only on this drawing ?
I am getting a consistent crash on a file when I switch to layout view. I get a "reused metafiles" message as it freezes. I'm looking for a cache to clear or something that might help.0
Perhaps it might help speed things up a little if "Cache layout" in your settings has its box ticked.
Otherwise, keep your files lean and clean via purge/ optimise and if things are still sluggish, please feel free to file a Support Request to us.
Many thanks.
Kin
