Dimension problem when moving from V20 to V21
I am having dimension problems moving from V20 to V21
I am attaching 2 jpeg images to illustrate my problem.
The dark panel shows the properties of a 1:10 annotative dimension correctly inserted.
The Light panel shows the properties of a 1:10 annotative dimension incorrectly inserted
You will notice in the Light panel (v21) the property of arrow size has been scaled to 1/10th of the size that it should be. In the dark panel (v20) the arrow size is is 3 which matches the dimstyle i am using.
Both of these dimensions have been inserted using the same drawing loaded into the respective versions using an annotative scale of 1:10.
Can anyone tell me what global variable is making this change? and how to fix the problem.
I can't believe that no one else has this problem. My work installation and my home installation both have the same problem
Should I be reporting this as a bug.
Here is another sample. Exact same drawing. Exact same dimstyle. The 1m box on the left was dimensioned in V20 and the one on the right in V21. It is also strange that the text on the dimensions is the same (correct) in both versions, but the scaling of the ticks, text spacing, extension lines etc are different.
Kind of makes V21 useless for the structural drawings I work on everyday.
I wouldn't even bother trying to switch from V20 to V21 except V20 would randomly crash when changing the annotative scale on a drawing.0 -
Do any of the Bricscad employees look at these forums or do I have to submit this bug to in some manner?
Hi!
This might be a bug. You could consider submitting a Support Request with Bricsys. To submit a Support request login to your Bricsys account and access this link here: New support request | Bricsys
Billie
Thanks
Just installed V22 and the problem seems to be fixed. YAY!!!!
