Palette Functionality
Palette-based content availability proved convenient in a (barely) competitive CAD application. Can someone comment on any efforts in adding either this exact or similar content organization functionality to BricsCAD?
Have you looked at the old fashioned image menu's as a solution ?
It is a solid option. Thanks!
BricsCAD has palettes. Unless you have a very old version you should be able to use them.
I will explore the newer version now. I thank you!
Howdy, Stranger!
