Non Real-Time PAN
hi all -
i used to use pan in it's non-real-time mode quite often - panning using pointing a direction and entering a distance.
just bought the V22 version, and it appears that PAN command does just what the PAN Real-Time is doing.
searched SETTINGS for a variable definition - not found one.
ideas, anyone ?
(i can clearly see a distinction in the icons of PAN & RealTime PAN)
  • You are looking for the -PAN command.
    https://help.bricsys.com/document?title=commandreference/CMD-pan.html&documentVersion=V22
  • Correct link is:
  • Mmm, still doesn't link correctly ...
    Alias for _-PAN is -P
    Thanx Louis -
    indeed the TYPING the command works out -
    problem is i can no longer assign a key to it the way i'm used to (Customize>>Keybord), since it isn't available among the other functions under the View category (actually, it DOES appear as an icon - same one i had in earlier BC version, only now in V22 it functions as RTPan and not as -PAN)
    i smply changed the sintax of the command in the proper CU>>Keyboard>>specific key, to -PAN as you said - and it works !
    Thanx, louis !
  • You can also edit the Pan tool in the View toolbox (CUSTOMIZE dialog box: Available tools / BricsCAD / View) and type a minus character in front of the command: '_-pan.
    By default the Pan tool is available in the Zoom toolbar.
    To easily repeat the command using a 'long right click' (= hold down the right mouse button a bit longer): set SHORTCUTMENU=22. Even when 'Show Quad on right click'=yes, the previous command will be repeated.
    thabx, Louis -
    both Tips were very useful !
