My properties window has gone.
Hi guys as the title says my properties window has gone. I can right click, and click on properties and get nothing. I did nothing on purpose with properties. How do I reistablish it. I am not finding my way around the program yet. Could somebody please assist. in detail on how to fet properties back. Screenshots would be highly appreciated as I am not fanilier with the UI yet and dont do much iof any advanced stuff
Thanks in advance
  • Are you on Mac ?
    In this case it is pretty usual that the left and right docked Palettes
    disappear every now and then, although the checkmark a) shows
    they should be visible and b) you can't deactivate that checkmark.
    Solution is usually to close and reopen the File.
    If not Mac,
    do you use dual or more Monitors ?
    Maybe the Properties Palette is on the wrong Monitor, outside
    of the Monitor area or behind the main Window, ....
    You could try to resize your Bricscad Window to search for the
    Palette or force Bricscad to bring it back in.
    If nothing helps, try hiding your Bricscad Config File, to start with
    a new generated config file. If that works your Config may be corrupt.
