Tolerances
Hi everybody,
I need to use tolerance on my projects however I was looking for some internal library available where I put the tolerance (e.g: 214g6) and the program give me the range (-0.015 / -0.044) but the only way that I could find is in Tolerance field at Dimension Properties but I have to put the range (upper and lower) and if I want to show the letter (g6) I need to insert it on Dim Suffix as unit.
Does anyone know about using tolerance in BricsCAD? Is it the only way to use?
Thank you in advanced.
