Issue starting Enscape for BricsCAD
Hello,
I'm trying to make some experinments to test Enscape for BricsCAD, so I installed BricsCAD V22 trial and then Enscape for BricsCAD V22 trial;
I started BricsCAD 3D, create a small 3d model and saved a view.
Then I started Enscape from the Enscape toolbar.... and I got this error message.
_startEnscape
An error occurred while updating the localization files: Impossibile trovare il percorso specificato.
Failed to initialize Enscape : (Enscape error (code 22): Cancelled.)
Could not initialize enscape.
Enscape encountered an error. : (Enscape error (code 1): Not implemented.)
Could anyone help me?
Matt
Hi Matt,
It seems like while creating the plugin, BricsCAD couldn't find a certain path.
Could you file a support request at https://www.bricsys.com/protected/support/NewSupportRequest.do so our developers can take a closer look at the issue. Thank you.Kind regards,
Chi-Yan
Howdy, Stranger!
