Drawing Customization/Typed Plans Problem
Is it possible to set up a Style(or appearance override) in such a way that 1 space is always represented by two different colors separated diagonally? see attachment.
Based on custom user properties of a space, I need to represent a space just like in the attachment using typed plans. Does anyone have a good idea how this could be done?
It is pretty simple to represent it with one color using the right style (color) and appearance override (solid). However I am still trying to find a way representing it with two colors without actually cutting the space in two halves.
Hi cand9139,
Thanks for your question. I am afraid Styles within the Typed Plan functionality do not support multiple colours (or gradients) yet.
Splitting the space into two halves could be a workaround for now - the only issue I could imagine is the potential to mess up the area/ room schedules and of course the space tags (ie. 2 space tags in 1 "room"). However if you are careful with them, I would imagine this could automated as much as possible with LISP routines perhaps splitting spaces into halves and renaming them too.
Kin
Hi Kin,
thank you for your answer.
For now, I will split the space, create a custom user property called ''Actual Area'' (Actual Area= Area x 2) for both halves, and use this property in space tags (tag only one space).
Hopefully this will be possible in one of the future updates.Almedin
