Recent problem publishing a PDF file longer than 5000mm
hi all -
on my earlier BC V15 i used to publish long drawings (needed for my work) - longer than 5000mm - i used an HP designjet driver, and got a PDF file accordingly (i then had problems printing that file to paper by a plotter at the local agency, but at least i had the PDF file correctly).
Moving to V22, using the same DSD file, page set up configuration etc., it's not working anymore - i get "paper size or margins are invalid" message at the command line after attempting to publish.
i know generally PDF are not possible beyond 5000mm (using, i.e. PDFCreator), but fact is it worked for me before, using the HPGL driver.
Anyone has an idea ?
Thanx,
Assaf
Dear Assaf,
there are the "ExpressTools for BricsCAD", a 3rd party freeware by Martin Drese;
you can download from
https://www.cadwiesel.de/cw_download_01.php?id=266
should work then :-)
many greetings ! -
Dear Assaf,
I'm sorry, that comment was intended for another forum entry :-(
many greetings !
Howdy, Stranger!
