points at end line
Hello,
I have closed 2D shapes, made from many lines. I need to insert block or point at each endpoint.
Can you please tell me what's the best way?
Thank you
  • Something like this
    ; add a circle to end of lines for import into the DRAINS software
    (setq oldsnap (getvar "osmode"))
    (setvar "osmode" 0)
    (command "layer" "n" "PITS" "Color" 1 "PITS" "s" "PITS" "")
    (setq ent (car (entsel "\nSelect drain layer: ")))
    (setq l_name (cdr (assoc 8 (entget ent))))
    (setq listlines (ssget "X" (list (cons 0 "line")(cons 8 l_name))))
    (setq listlinesno (sslength listlines))
    (setq y 0)
    (repeat listlinesno
    (setq pt1 (cdr (assoc 10 (entget (ssname listlines y)))))
    (command "circle" pt1 1.0)
    (setq y (+ y 1))
    ) ;end repeat listlineno
    (setvar "osmode" oldsnap)
