View rotates to match text alignment when editing.
Recently updated to V22. Now when I double click on a single line text object to edit it, my view rotates to match the text angle. For example if my text is rotated 90 degrees, while in the editing command my view will rotate to match it. V21 didn't do this. Is there a setting or variable for this to keep my view at standard rotation while editing?
Set MTEXTFIXED = 0.
AHH, thank you! I knew there was a variable for it somewhere, just couldn't remember and all my searches were turning up nothing.
