Send Command by C#
I want to call and run my command with arguments through C# can anyone help me out in this?
i have tried:
Document doc1 = _AcAp.Application.DocumentManager.MdiActiveDocument;
doc1.SendStringToExecute("MyCommand", false, false, true);
also:
doc1.SendCommand("MyCommand");
but it didn't worked.
TIA.
i have tried:
also:
TIA.
You might try with an added enter/return (as NewLine character) appended to "MyCommand" :
"MyCommand\n"
that mimics the return/enter on commandline ... next input then should be the arguments as requested :
"MyCommand\nArg1\nArg2\n.....\n")
does it help ?
many greetings !0 -
yes it works!!
thank you so much!!!
Torsten Moses.0
