BIMDIMENSION command not working on sections
Hello,
in the last days I've been using the new BIMDIMENSION command with profit on plan sections. I believe it's a game changer. I have a problem on normal sections - simply, it doesn't seem to find BIM objects to hook to. I thought there could be issues with the sections, but automatic and manual tags work fine.
Any ideas what I could do?
Fabio
  • Hi Fabioski,
    the problem is known and is a bug (Bimdimension currently only works on sections of type 'plan').
    It will be solved in one of our upcoming releases.
    Thank you for the feedback.
  • Thank you very much Piet. I can't wait for this bug to be solved, the command is really good. Although yesterday I found out i didn't work in a couple of plans too.
