Print as PDF - Refresh MediaNameList
Hallo
i create a costum paper size for the Printer "Print As Pdf.pc3" programmatically with c#. I refresh the MediaNameList to with the following code:
var pdfConfig = PlotConfigManager.SetCurrentConfig("Print as PDF.pc3");
pdfConfig.RefreshMediaNameList();
After that i like to set the new paper size in the PlotSettings:
Using (var ps = new PlotSettings(layout.ModelType))
ps.CopyFrom(layout);
var psv = PlotSettingsValidator.Current;
psv.SetPlotConfigurationName(ps, pc3FilenameForPDF, "");
psv.SetCanonicalMediaName(ps, papierFormat);
But that doesn't work. "Teigha.Runtime.Exception: "eInvalidInput" What can i do ?
thanks.
