file saving read only problem
                                  in Other
                    Hi all
Using bcad v22, after opening new or exiting file, it automatically becomes a read only file, can not be saved wit save comand , only save as works, what force me to rename it every time
Please where is the problem? i just need to work, open change and save a file with the same name...
thanks!
thanks!
            Hello,
I have the same issue here wit V21.
Did you solve this problem already?
Thanks0 -
            Hi I solved, it was antivirus- avast seting, bricscad v22 was blocked0
            restore an autosave document
