Block With Solids and Attributes into Brics BIM
I have many 3d models of structures comprising of blocks with default preset invisible attributes and solids. These can be grouped into another level of block to form welded assemblies. The attributes are extracted to form BoM's via ddattext. The solids are made up of standard sections, angles, circular hollow sections etc. What is the best way to bimify without losing the attributes? It would appear bimify cant run in refedit active.
Also, I have holes and crops etc on the 3d solid sections. If I explode then bimify works but blockify does not allow the attributes to be attached and its a lengthy process.
  • Kin
    Kin
    edited January 2022
    Hi peterima,
    I presume the main purpose of using the bimify tool in your case is to autoclassify your objects rather than to create corresponding sections and views? If so, I believe a workaround would be to go into the block editor and Classify the objects manually.
