Stretching an Ellipse?
Has anyone figured out how to stretch an Ellipse without resorting to the grips? In AutoCAD, you can create a stretch window across an endpoint and drag it out to increase the Ellipse. BricsCAD ignores a stretch window on the Ellipse, and only allows you to stretch it via grips. Needless to say this does not work well in a dynamic block setting.
