Diesel Expressions in BC from AC
Hi All,
I have a titleblock with some diesel expressions embedded which works in AC but not BC.
All of the imported Diesel expressions seem to struggle - outputting: $(IF, ??)
This is one example:
%<\AcDiesel $(if,$(eq,$(substr,$(getvar,DWGNAME),10,3)," - "),$(substr,$(getvar,DWGNAME),13,99),$(substr,$(getvar,DWGNAME),17,$(-,$(strlen,$(getvar,DWGNAME)),4)),) > \f "*%fn2">%
The drawing name is: 00000-000 - My Drawing.dwg -
In AC in correctly outputs My Drawing into the field.
In BC it outputs: $(IF, ??)
Can anyone help with this? Is there anything that jumps out at being a problem here?!
Cheers
  • Hi Again,
    More simply, dose anyone know if diesel should be the same in BC as AC?
  • yes, it should be the same :-(
    best, to report that issue to our SupportRequest system, so it gets logged to the database, and analysts & developer can care to get this fixed/improved.
    many greetings !
