Attsync all blocks instances in a file
Hallo
I noticed the behaviour of ATTSYNC command is different that Autocad:
when I run the command and select a block, ONLY THAT ONE INSTANCE of the block is updated not all the others.
This means I need to run ATTSYNC individually on ALL INSTANCES of the same block which is very laborious.
In Autocad ALL INSTANCES of the same block where updated.
Any way to achieve this ? mayve a variable I am missing?
Thanks
luca
Thanks
luca
In my v14, all instances in the drawing are updated. Are there perhaps settings that can change the behavior?
-Joe0
