mutual gripping not working now ...
hi all -
on previous BC versions, the following was something i used quite a lot -
hatch entity within a polygon >> selecting both entities >> gripping a certain grip-point (be it an end point, mid-point, etc.) >> stretching the geometries by moving that one grip-point.
because both grip-points of each geometry were on top of each other, stretching that grip affected both geometries simultaneously.
in my new V22 BC - it's not happening :-( and they don't change together.
i guess it' a variable matter - can anyone help ?
Me too - so I assumed it's normal, not just a v22 'feature'. Mind you, hatches with grips is also new to me.0
autocad had for sometime grips on hatches actually its a dwg with hatch bounded by a polyline in some cases , don't know what your's is but I've ran across it before, un usual animals, have to play with it to learn what to do next time.0
manipulating a hatch in this manner is very useful, actually, ans since many times that hatch is bounded by a polyline, changing one usually comes with changing the other.0
