Using parameters in sheet metal properties
Why cant I link a parameter to the sheet metal properties?
Similar if I want to control the amount of slots its not possible.
Will this be comming in version 23?
Hello Linnemann,
Its possible to link a parameter a sheetmetal propertie like the thickness. See image below.
I can confirm that its currently not possible to link a parameter to the number of tabs.
I recommend you make a service request on the bricsys site.0
