Connect Profiles in Mechanical
In BIM mode it is possible to connect profiles with straight cut or miter connection.
Why is this not possible in Mechanical?
Would be an immense time saver, similar to sheet metal, to have a seperate drawing with all the profiles with an easy to generate BOM with Type, lengths and miter angle etc. Also in the below video.
A request would be to allow to draw a simple 2D sketch and then apply a profile to the whole sketch/polyline similar to how Solid Edge does it.
https://www.youtube.com/watch?v=4aaiEEjzjTQ
https://www.youtube.com/watch?v=4aaiEEjzjTQ 0
