Function: POINTCLOUDFITPLANAR
Hey
When I use the function pointcloudfitplanar in the Bubble view, the surface is too long.
It doesn't matter if I use the mode rectangle or contour.
This is a picture from my model:
Do you have any idea why that is the case?
Thank you in advance for your help
When you use POINTCLOUDFITPLANAR in de Bubble Viewer, you can Quickselect (press Shift-key) multiple surfaces at once, those surfaces will be automatically connected so you don't have those long surfaces.
Kind regards,
Chi-Yan
Hey
Thank you, but it doesn't always work.
I have this object. How would you model this?
The windows give me the most trouble.
Thank you in advance for your help.
Kind regards
Jasmin
