KDE Plasma bricscad window is demanding attention in task manager
In KDE, the Bricscad application is demanding attention everytime. This is very anoying when you have configured de panel with auto hide because the bar hides application areas.
In the case of bricscad the hided area is the command line that makes imposible to work with the window maximized.
Is there any way to avoid this behaiviour?
Must be a sign from above that you should never let anyone fool you into hiding the command line in CAD. Unhide it permanently with the 'COMMANDLINE' command
