Which Directory does Express Tool Load into?
I've attempted to load the V21 express tools (I'm running V22) and I get an error message during the Setup. During setup I get the
1. Load the Application question Yes or No....I select Yes
2. Select the Language. English is default so I select OK
3. I get the warning exclamation mark with the message APPLICATION not installed, aborting installation. Only option here is OK so I select the box for OK
4. The next screen is the Select Destination Location (Where should Express Tools be installed?) and the installation directory structure is blank (where one might imagine the destination directory and structure would be located.)
I'm thinking the ExpressTools V21.exe is looking for V21 and not V22 so that is causing the hiccup.
Regardless, any help is appreciated.
For Bricscad V22 install Express Tools for V22 !
https://www.cadwiesel.de/index.php?hp=downloads&anzeigedatei=downloads&cat=Etools&dbcat=Etools0 -
Yes, you need the ExpressTools V22 installer. Please download it from the publisher site: https://www.cadwiesel.de/index.php?hp=downloads&anzeigedatei=downloads&cat=Etools&dbcat=Etools&sprachauswahl=english0
Thank YouLyubov_Osina said:Yes, you need the ExpressTools V22 installer. Please download it from the publisher site: https://www.cadwiesel.de/index.php?hp=downloads&anzeigedatei=downloads&cat=Etools&dbcat=Etools&sprachauswahl=english
