Drag open
Hello.
I have a problem with "dragopen" command.
It is set to open dragged file, but whenever there is existing block on drawing, drag and drop makes block of dragged file instead of open it.
Thank you.
Thank you.
This happens with me as well when dragging a file into the drawing window.
If you drag the file onto anything in BricsCAD but the drawing window, e.g. an empty part of the ribbon area, the menu bar or the application title/filename area or even the command window area, it should open as a file instead of being inserted into the drawing as a block.0 -
Hello,
good old rule "always use drag & drop" with the *RIGHT* mouse button :-)
then a popup menu will appear what to do ... "open", "insert" and so on, depending on dropped file type.
hope this helps ?
many greetings !0 -
Thank you both.
That are good solutions to circumvent a problem, but I still want to know how to drag it directly, like it should... :-)
Best regards. ;-)0 -
There is also DRAGOPEN setting (system variable) which defines whether to 'Open' or to 'Insert' the dragged dwg file ... maybe that helps as well ?
many greetings !0 -
It is already set to "open"0
Dear Dusan,
you might send us a SupportRequest, with 2,3 sample dwg files, and short explanation of your operation ...
for sure, we will quickly pick this up, to improve our operations here.
thanks in advance & many greetings !0
