3D connexion Space mouse wireless does not rotate
My 3D connexion space mouse won't rotate anymore, It has worked, but I want to assign a function to the middle mouse buttton and I suspect something went wrong. The feature didn't work, but I couldn't remember what was the function before, so I couldn.t put it back.
Then I uninstalled and reinstalled Bricscad and the 3D mouse software but the rotation funtion is not working.
Is there a setting I can change?
Because you mention middle mouse button I suppose you might actually be referring to the CADMouse, because the SpaceMouse does not have a middle mouse button.
For the rotate to work you also have to hold the CTRL or SHIFT key before pressing down the middle mouse button depending on the kind of rotation you want.
You could reset the CadMouse settings in the 3D Connexion control panel to see if that makes a difference.0
