Change the exterior side of an window to inteior and vice-versa
Good morning,
I have in my BricsCAD model placed some windows as is possible to see in the image 1 by the exterior view of the building:
The situaton that is happening - not desired - is that the windows parameter: PlacementDepth is 200, but on the inside of the building, as it's possible to see in image 2:
How can I change the exterior/interior definition of the wall in order to have the PlacementDepth of 200 counting from the other side of the wall, my ideia of exterior side?
Thank you,
Best regards,
Lucas Samuel Nepomuceno
Thank you,
Best regards,
