TILES IN ELEVATION
Hallo
I am generating interior elevations for bathrooms using large tiles (150 x 150 cm) and would need to include a tile setting out showing grouting / cut lines abd false colors on the elevations to show installers tiles should be cut and aligned be preserved. See below an example:
1) I tried applying an elevation Hatch in the composition , but that only works with a generic hatch pattern (small size repetitive tile patterns).
2) I tried drawing 3Dpolylines on the elevation where grouting lines will be , but they are not showing up on the elevation view : why ? are simple polylines not projected on the elevations?
3) Another options would be drawing them in 2D layout once the elevation has been generated (last resort...) as a 2D entity but this would be problematic as often these lines need to match bot walls and floors and are studied in 3D.
4) last resort would be to actually model the tiles and then be able to assing materials.
Question is if there is any way to have a 2D polyline show in the section / elevation view ?
Or any other method to rapresent tiles in elevation ?
Thanks
Luca
Thanks
Luca
1
