PDF IMPORT - NOT IMPORTING VIEWPORT AND INFORMATION GENERATED FROM XREF MODEL
I am able to pdfimport [file option] external consultants pdfs[I presume non viewport] and convert to simple .dwg but when I tried to import one of my own pdfs initially generated from paper space layout/externally referenced model, only title blocks, notes in paper space are shown. All viewport information is missing. I'm sure it will be a variable that I need to change while creating original pdf.
When I tried pdf attach, all information was displayed, but when I then used pdfimport to convert to .dwg and selected attachment, once again viewport information did not display.
I am using 21.2.05 (x64) revision c77687b2 as V22 is still a bit unstable and I am still having the Publish multi sheet issue as per my previous support request.
Cheers
Murray
Cheers
Murray
PDF files are the most widely misunderstood file formats in the computing world. When a user looks at a PDF Preview they see things as they remember them in the DWG file, but that is the farthest thing from the case.
There are absolutely ZERO intelligent objects in a PDF file. There are only paths, text and images, there is not even a true circle object, it's usually 4 bezier curves (even though a handful of readers reassemble them). Many times things that look like text is a collection of vectors. Many times things that look like vectors are actually a highly compressed high resolution image. In summary a PDF is a DUMB PLOT FILE and users need to stop expecting more from them than exists! You want more, ask for a DWG file.0
