V22 window/door doesn't snap to face of wall
Problem still not solved.
Fred0 -
Hi Fred,
Could you check if you have this settings on?
Which v22 version are you using? Mine works fine - DUCS turned on, and even with the "walls" unclassified to become simply a vertical plane.
Kin0 -
Thank you Kin,
Enable for faces of 3d solids was off.
Don't know how this could happen.
Greetings Fred0
