drawing customization
can anybody help me?
i cannot enable, turn on or whatever the drawing customization panel,
in the panels or at all,
right click in the panels the “drawing customization” is missing in the menu, so I cannot select it.
if I put it in a toolbar, it is just greyed out and nothing happens when pressing it,
where is it? How can I enable it?
In v21 it is just there, and I turn it on in the panels, but in v22 it's simply not there.
f.
  • Hi f.
    "drawing customization" is called "typed plan" now (tag customization is added). You can manage your "typed plans" templates with the command TYPEDPLANS. But when you are in a bim project you can set up a new, edit or import an existing via the projectbrowser (big blue plus button at the bottom of the folders tab)
  • TYPEDPLANS,
    Thank You!
