rotated dimension
in Other
Is it normal for the software to rotate the drawing when I have a vertical aligned dimension?
I know that AutoCAD does not do this and it's very confusing when working with multiple annotations.
AFAIK there was a Setting if it will rotate the view for better text visibility
while editing or not.0 -
it would be very helpful to know where to find the setting.Michael Mayer said:AFAIK there was a Setting if it will rotate the view for better text visibility while editing or not.
Got the response from the support : MTEXTFIXED = 10
